Page Revision: 2009/01/06 22:28
Boice-Crane 1400 6" Jointer
* 6203-LL (17mm B, 40mm OD, 12mm W)
Buffalo Forge No. 18 Drill Press (w/ external screw table lift)
  • Quill:
    • Upper: 88505 ND > 88505 KS
  • Pulley:
    • Upper: 88508 ND > 88508 IF
    • Lower: 88508 ND > 88508 IF
  • Lift table:
Delta Bullet Motor
  • Bullet Motor: 87504
Delta 14" Bandsaw, Wood Cutting
  • Newer Style:
    • Upper wheel: 6202LL Nachi
    • Lower wheel: 6204LL Nachi
  • Older Style:
    • Upper wheel: 87502
    • Lower wheel: 87504
  • Guides: 6200LL Nachi
FORMATTER ERROR (Malformed List)
Delta Unisaw
  • Arbor:
    • Thinner/Older spacers: 88503
    • Thicker/Newer spacers: 6203
Parks 12" Planer
  • 2x 6204
Walker-Turner 14" Wood Bandsaw
