Page Revision: 2010/02/03 14:01
- This list contains ball bearing information for machines sold by Sears.
- Original Bearings: ?
- Accurate Replacement: none (odd size)
Motors
115.5652 Dunlap 1/3 hp: original-ND USA ENDEE 8013, Accurate replacement-87013
115.6960 Dunlap 1/3 hp: original-ND USA 8013, Accurate replacement-87013
113.12180 Craftsman 1/2 hp: original-Nachi 620310Z, 6203 with 5/8" bore, double shield
Accurate replacement-6203-5/8
113.19040 Craftsman 1 hp: original-
_, Accurate replacement-6203
115.19801 Craftsman 1/2 hp: original-MRC_202_SFF_4, 6202 double shield
Accurate replacement-6202
397.19821 Craftsman 1/2 hp: original-_, Accurate replacement-6203
Common Bearing Specs
8013: OD=32mm, ID=13mm, W=10mm, 3mm extended inner race on one side
