Page Revision: 2010/02/03 14:25
  • This list contains ball bearing information for machines sold by Sears.
  • Original Bearings: ?
Motors
Bearing Specs
Brg Bore OD W Ext Race Width 6202 15mm 35mm 11mm - 6203 17mm 40mm 12mm - 6204 20mm 47mm 14mm - 8013 32mm 13mm 10mm +3mm one side R8ZZ .5000” 1.1250” .3125” -
