Page Revision: 2010/02/03 14:37
  • This list contains ball bearing information for machines sold by Sears.
  • Original Bearings: ?
Motors
Bearing Specs
Brg# / Bore / OD / Width / Ext race 6202: 15mm / 35mm / 11mm / - 6203: 17mm / 40mm / 12mm / - 6204: 20mm / 47mm / 14mm / - 8013: 32mm / 13mm / 10mm / +3mm one side R8ZZ: .5000” / 1.1250” / .3125” / -
