Page Revision: 2010/02/03 14:51
- This list contains ball bearing information for machines sold by Sears.
- Accurate Replacement: none (odd size)
Motors
Bearing Specs
Brg# / Bore / OD / Width / Extended Race
8013: 32mm / 13mm / 10mm / +3mm one side
