Page Revision: 2010/02/22 12:21
Grinder/Polishing Head
  • Accruate Replacement: 6202ZZ (double shield) or 6202LL (double seal)
Craftsman 103.23340 4-3/8"
  • Accurate Replacement: R8ZZ
Motor
Bearing Specs
