Page Revision: 2010/04/26 15:49
Grinder/Polishing Head
Craftsman 103.23340 4-3/8"
  • Accurate Replacement: R8ZZ
Motor
115.19020 Craftsman 3/4hp: - Fan end: original-ND (USA) 3203 double shield; Accurate replacement-6203 - Klixon end: original-ND (USA) 8503 shield inner/open outer; Accurate replacement-87503
113.19040 Craftsman 1 hp: original-Norma (USA) 203PP double shield ; Accurate replacement-6203
Sander
Bearing Specs
