Page Revision: 2010/06/06 22:22
Grinder/Polishing Head
  • Accurate Replacement: 6203
Craftsman 103.23340 4-3/8"
  • Accurate Replacement: R8ZZ
Motor
115.19020 Craftsman 3/4hp:
113.19040 Craftsman 1 hp: original-Norma (USA) 203PP double shield ; Accurate replacement-6203
Sander
Bearing Specs
