Page Revision: 2012/12/20 06:27
Grinder/Polishing Head
Craftsman 103.23340 4-3/8"
  • Accurate Replacement: R8ZZ
Motor
115.19020 Craftsman 3/4hp:
551.1939-1 Craftsman 1hp:
Sander
Craftsman 113.23940
  • Accurate Replacement: 6202 (double seals)
Bearing Specs
