Page Revision: 2014/03/17 13:35
Grinder/Polishing Head
Craftsman 103.23340 4-3/8"
  • Accurate Replacement: R8ZZ
Motor
113.12180 Craftsman 1/2 hp: original-Nachi 620310Z, 6203 with 5/8" bore,double shield, Emerson p/n 37161 Accurate replacement-6203-5/8, Sears replacement-STD315238
115.19020 Craftsman 3/4hp:
113.19060 Craftsman 1 hp: original-Norma (USA) 204PP double shield, Emerson p/n 24237 Accurate replacement-6204, Sears replacement-STD315245
551.1939-1 Craftsman 1hp:
Sander
Craftsman 113.23940
Bearing Specs
