Page Revision: 2014/05/21 22:33
Grinder/Polishing Head
Craftsman 103.23340 & 103.21820 4-3/8"
  • Accurate Replacement: R8ZZ
Motor
  • Accurate replacement-6203-5/8, Sears replacement-STD315238
115.19020 Craftsman 3/4hp:
  • Accurate replacement-6204, Sears replacement-STD315245
551.1939-1 Craftsman 1hp:
Sander
Craftsman 113.23940
