Page Revision: 2014/05/22 07:02
Grinder/Polishing Head
- Accurate Replacement: 87502
- Accurate Replacement: 1622
Craftsman 103.0502 4-1/4"
- Accurate Replacement: R8ZZ
- Emerson part number: 18229
Motor
- Accurate replacement-6203-5/8, Sears replacement-STD315238
115.19020 Craftsman 3/4hp:
- Accurate replacement-6204, Sears replacement-STD315245
551.1939-1 Craftsman 1hp:
- Original Bearings: (TBD)
Sander¶
Craftsman 113.23940
