Page Revision: 2014/05/22 07:27
Grinder/Polishing Head
Craftsman 103.0502 4-1/4"
  • Accurate Replacement: R8ZZ
  • Emerson part number: 18229
115.7429 Craftsman: Accurate replacement-6202-5/8 (double check yours--possibly different brgs over production run), Packard p/n-908502
410.12500 Craftsman: B-B p/n B-5193-BB-203
115.19020 Craftsman 3/4hp:
  • Accurate replacement-6204, Sears replacement-STD315245
551.1939-1 Craftsman 1hp:
Sander
  • Emerson part number: 39815
