Page Revision: 2014/05/22 07:55
Craftsman/Dunlap 103.0103
  • Original bearings: Hoover 7720-10 (earlier models had SKF bearings); Central Specialty part number X-1704
Grinder/Polishing Head
Craftsman 103.0502 4-1/4"
  • Accurate Replacement: R8ZZ
  • Emerson part number: 18229
Sander
  • Emerson part number: 39815
