Page Revision: 2014/05/22 08:07
Band Saw¶
Craftsman/Dunlap 103.0103
-Original bearings: Hoover 7720-10 with shield on one side (some machines equipped with SKF ball bearings), Qty=4
Guide thrust bearings: single ball 7/32" diameter, Qty=2
Grinder/Polishing Head
- Accurate Replacement: 87502
- Accurate Replacement: 1622
Craftsman 103.0502 4-1/4"
- Accurate Replacement: R8ZZ
- Emerson part number: 18229
- Original Bearings: (TBD)
Sander¶
- Emerson part number: 39815
