Page Revision: 2014/05/22 08:10
Craftsman/Dunlap 103.0103
- Original bearings: Hoover 7720-10 with shield on one side (some machines equipped with SKF ball bearings), Qty=4
    Grinder/Polishing Head
    Craftsman 103.0502 4-1/4"
    • Accurate Replacement: R8ZZ
    • Emerson part number: 18229
    Sander
    • Emerson part number: 39815
  • ScrewTurn Wiki version 3.0.5.600. Some of the icons created by FamFamFam.
