Page Revision: 2014/05/22 10:40
Craftsman/Dunlap 103.0103
Grinder/Polishing Head
Craftsman 4¼" 103.0502
Craftsman 4-3/8" 103.23340, 103.21820, 103.20670, 103.20680
  • Accurate Replacement: R8ZZ
Craftsman 6" 103.23900, 103.20660
Craftsman 6" 103.23320 Craftsman 6-1/8" 103.20620, 113.20621
Craftsman 6-1/8" 113.20650, 113.206801, 113.206801, 113.206933
  • Emerson part number: 3509
  • •Accurate replacement: 6202ZZ-5/8 (double shields) or 6202LL-5/8 (double seals)
  • Emerson part number: 18229
Sander
  • Emerson part number: 39815
