Page Revision: 2014/05/22 10:42
Craftsman/Dunlap 103.0103
Grinder/Polishing Head
Craftsman (4¼") 103.0502
Craftsman (4-3/8") 103.23340, 103.21820, 103.20670, 103.20680
  • Accurate Replacement: R8ZZ
Craftsman (6") 103.23320 Craftsman (6-1/8") 103.20620, 113.20621
Craftsman (6-1/8") 113.20650, 113.206801, 113.206801, 113.206933
  • Emerson part number: 3509
  • •Accurate replacement: 6202ZZ-5/8 (double shields) or 6202LL-5/8 (double seals)
  • Emerson part number: 18229
Sander
  • Emerson part number: 39815
