Page Revision: 2014/05/22 14:03
Craftsman/Dunlap 103.0103
Craftsman (6") Cat# 2601
Craftsman (6") 103.6604
Craftsman (6") 113.6604
Grinder - 6" Electric
Companion 115.5273
Craftsman 115.7561
Craftsman 397.19391
Craftsman 115.19500
  • Packard part number: 954832
Craftsman 397.19589
Grinder - 7" Electric
Craftsman 115.6965
Craftsman 115.7575
Grinder - 8" Electric
Craftsman 397.19670
  • Original bearings: (TBD)
Craftsman (4¼") 103.0502
  • Accurate Replacement: R8ZZ
Craftsman (6") 102.05600
Craftsman (6") 103.23320
  • Emerson part number: 3509
Dunlap 534.0601 9x30 Belt Driven Woodworking Lathe, Qty=1 thrust ball bearing
  • Emerson part number: 18229
Sander
  • Emerson part number: 39815
