Page Revision: 2014/06/02 09:15
  • Original bearings: (TBD)
Craftsman (12") 103.24250
Craftsman 103.23100
Craftsman (6") Cat# 2601
Craftsman (6") 113.6605
Grinder - 6" Electric
Companion 115.5273
Craftsman 115.7561
Craftsman 397.19391
Craftsman 115.19500
  • Packard part number: 954832
Craftsman 397.19589
Grinder - 7" Electric
Craftsman 5120 (Cat# 2609)
  • Accurate replacement: 6204
Craftsman 115.6965
  • Accurate replacement: 87502
Craftsman 115.7575
  • Accurate replacement: 6203
Craftsman 397.1949
Grinder - 8" Electric
Craftsman 397.19670
Craftsman (4¼") 103.0502
  • Accurate Replacement: R8ZZ
Craftsman (6") 102.05600
Craftsman (6") 103.23320
  • Emerson part number: 3509
  • Emerson part number: 18229
Sander
  • Emerson part number: 39815
