Page Revision: 2016/08/31 06:23
Table of Contents [Hide/Show]
      Craftsman (12") 103.24250
      Craftsman 103.0303
      Craftsman 103.23100
      Craftsman 103.23130
      Craftsman 103.2482x
      Craftsman (6") Cat# 2601
      Craftsman (6") 113.6605
Grinder - 6" Electric
      Companion 115.5273
      Craftsman 115.7561
      Craftsman 397.19391
      Craftsman 115.19500
      Craftsman 397.19589
Grinder - 7" Electric
      Craftsman 5120 (Cat# 2609)
      Craftsman 115.6965
      Craftsman 115.7575
      Craftsman 397.1949
Grinder - 8" Electric
      Craftsman 397.19670
      Craftsman 257.192190
      Craftsman (4¼") 103.0502
      Craftsman (6") 102.05600
Sander
      Dunlap 534.09760
  • Original bearings: (TBD)
Craftsman 103.0303
Craftsman 103.23100
Craftsman 103.23130
Craftsman 103.2482x
Companion 115.5273
Craftsman 115.7561
Craftsman 397.19391
Craftsman 115.19500
  • Packard part number: 954832
Craftsman 397.19589
  • Accurate replacement: 6204
Craftsman 115.6965
  • Accurate replacement: 87502
Craftsman 115.7575
  • Accurate replacement: 6203
Craftsman 397.1949
Craftsman 397.19670
  • Accurate Replacement: R8ZZ
  • Emerson part number: 3509
  • Original spindle bearing (Qty-2): Atlas part number- 60-31; SKF 6205-Z EC L-05-Z (shield to outside of headstock, open inward); Accurate replacement-6205LL (seals) or 6205ZZ (shields)
  • Qty=2 ball bearings
  • Emerson part number: 18229
Sander
Dunlap 534.09760
  • Emerson part number: 39815
