Page Revision: 2010/02/03 14:13
  • This list contains ball bearing information for machines sold by Sears.
  • Original Bearings: ?
Motors
Common Bearing Specs
8013: OD=32mm, ID=13mm, W=10mm, 3mm extended inner race on one side
