Page History: Help - Table Formatting
Page Revision: 2008/03/29 10:36
The
WikiMarkup used in
ScrewTurn Wiki supports tables, using a well-known syntax. Inserting tables is simple, but you can also modify the appearance of the tables.
1 - Basic Tables
A simple table is composed by a sequence of rows, and each row contains some cells.
| Cell 1.1
| Cell 1.2
| Cell 2.1
| Cell 2.2
|}will results in
| Cell 1.1 | Cell 1.2 |
| Cell 2.1 | Cell 2.2 |
Depending on the theme you are using, tables' appearance might differ.
The same results can be obtained using the form
| Cell 1.1 || Cell 1.2
| Cell 2.1 || Cell 2.2
|}As you can see, a table starts with
{| and ends with
|}. A single pipe starts a cell of the table, while a pipe with a hyphen (
|-) starts a new row in the table.
A double pipe separates two or more cells in the same row.
2 - Advanced Options
A table can have a
caption (or title). You can specify it using a pipe and plus, just after the opening tag.
|+ This is a Table
|}produces
This is a Table| Cell 1.1 | Cell 1.2 |
You can also use row and cell headers; they are identified with a exclamation mark.
! Cells x.1 !! Cells x.2
|}generates
| Cells x.1 | Cells x.2 |
You can use row headers as well.
! X !! x.1 !! x.2
! 1.x
! 2.x
|}generates
| X | x.1 | x.2 |
| 1.x | Cell 1.1 | Cell 1.2 |
| 2.x | C |
ell 2.1Cell 2.2 |
3 - Table Appearance
You can modify the appearance of a table (and each row or cell) using XHTML tags.
{| border="1" bgcolor="Gray"
|}generates
You can also modify the appearance of single rows. In this case, you can add a trailing row separator manually.
{| cellspacing="0" cellpadding="2" border="1"
|- style="background-color: Red; color: White;"
|- style="font-weight: bold;"
|}results in
Even single cells can be
styled.
| bgcolor="Blue" | Styled Cell
| Normal cell
| Normal cell
| bgcolor="Yellow" | Styled cell
|}| Styled Cell | Normal cell |
| Normal cell | Styled cell |
4 - Merging Cells
You can use XHTML attributes to merge two or more cells (horizontally or vertically).
Note: not all the the browsers support this feature.
| colspan="2" bgcolor="Red" | Cell
| Cell || Cell
|}generates
While
| rowspan="2" bgcolor="Red" | Cell
| Cell
| Cell
|}results in
5 - Alignment
You can align a table to the right or place it in the center of the page.
{| align="right" border="1"
| Cell || Cell
|}produces
while
{| style="margin: 0px auto;" border="1"
| Cell || Cell
|}results in
6 - All Together
{| cellspacing="0" cellpadding="2" style="background-color: #EEEEEE;"
|+ Styled Table
|- style="background-color: #990000; color: #FFFFFF;"
| This is a cell || This is a cell || This is a cell
| style="background-color: #000000; color: #CCCCCC;" | Styled cell
| style="border: solid 1px #FF0000;" | Styled cell
| '''Normal cell'''
| Normal || Normal || [Download]
|}produces
Styled Table| This is a cell | This is a cell | This is a cell |
| Styled cell | Styled cell | Normal cell |
| Normal | Normal | Download |
