Page Revision: 2012/01/18 00:45
- Replacing the brushes
Once done, the commutator looks far better than it was half an hour earlier.
The "shorting necklace" inside the commutator is often one of the most common failure points on a Unisaw RI bullet motor. It is also one of the most troublesome parts to either locate for replacement. In addition to showing one method for fabricating a new shorting necklace from small extension spring stock, the page also shows demonstrates briefly the turning the commutator and undercut the mica, as well as replacing the brushes
