Page Revision: 2012/01/18 00:52
- Replacing the brushes
The "shorting necklace" inside the commutator is often one of the most common failure points on a Unisaw RI bullet motor. It is also one of the most troublesome parts to either locate for replacement. In addition to showing one method for fabricating a new shorting necklace from small extension spring stock, the page also shows demonstrates briefly the turning the commutator and undercut the mica, as well as replacing the brushes
