Page Revision: 2012/01/18 01:02
- Replacing the brushes
The "shorting necklace" inside the commutator is often one of the most common failure points on a Unisaw RI bullet motor. It is also one of the most troublesome parts to locate for replacement. The following discussion shows how to remove the shorting necklace, assess its condition, and one way to fabricate a new shorting necklace from extension spring stock.
Replacing the Brushes
