Page Revision: 2012/01/21 00:23
- Replacing the brushes
The "shorting necklace" is a circular spring, sometimes called a garter spring, inside the commutator, and is often one of the most common failure points on a Unisaw RI bullet motor. It is also one of the most troublesome parts to locate for replacement. These The following discussion shows how to remove the shorting necklace, assess its condition, and one way to fabricate a new shorting necklace from extension spring stock.
With the length of ~8" confirmed, on to making a new spring. The original OEM necklace is made out of an extension spring, using 3/32 .018 wire. That specific wire can be hard to find, but a very close approximation is a 1/8 .018 wire that is available from on-line sources such as McMaster-Carr (www.mcmaster.com, this example was $4.00 plus s/h for a 36" length). The 1/32 difference in outside diameter (OD) should not matter for purposes of this part. Because the old spring was deformed and stretched, the new piece that was cut for this project was about 1/2" shorter total length (7.5") than the original spring.
Replacing the Brushes
New brushes can be found on-line and are not particularly expensive. This new pair was found at Eurton Electric (www.eurtonelectric.com) for $25 plus s/h. They certainly look better than the old ones.
These are new brushes installed in the brush ring. It looks about the same front and back as the old ones. Note the wiring location on the back side of the ring. 1) Be sure that they are wrapped around the side that does not have the opening in the cover flange -- that is where the adjustments will be done after reassembly, so the wires should not be place there where they will interfere. 2) Make sure they sit flat on the plate, so that they don't get caught under the assembly when it is flipped upside-down and reinstalled in the endbell.
