Page Revision: 2012/11/20 23:22
- Replacing the brushes
Spring LengthFirst, it is necessary to measure the length of the spring. Obviously, the easiest way to measure it would be to simply cut it and lay it straight to measure. But sometimes it may be worth measuring it intact as a circle, perhaps to save it for emergency use later or to compare the new one against as a final check on correct size. Note that different motors have commutators of different size, so the dimensions shown here may not be correct for a given motor.
As a first thought, one might consider simply using measures of the original damaged necklace. The diameter of this one that's being replaced is about 2.5", which, using basic algebra (pi * diameter), suggests the circumference/length should be just under 8". However, old springs can tend to be stretched or the damaged portion can be misleading. So other, more precise methods are probably preferred. The following paragraph about springs and lengths was extracted from a post on the www.owwm.org forum site where this particular motor rebuild was discussed (http://www.owwm.org/viewtopic.php?f=82&t=107557).
Now it seems to me everyone is wondering exactly how long to cut the spring. Some have used the old spring as a model and tried to guesstimate how long it originally was. I found this probably won't get you close, especially if your spring is badly deformed. So I approached this a bit differently. First one must understand how a spring works. Take any spring and unwind it and you have a straight wire. If you clamp one end of the wire in a vise and grab the other end with pliers and twist it, you will find there is certain amount of rotational force you apply before the wire breaks. There is also a certain amount of force that can be applied and released and the wire returns to its' original form. This is what makes it a spring...the ability to return to a set configuration after being deformed. And the amount of force required to twist the wire is dependent upon the diameter and length of the wire. You might be able to "twist" a 1 foot section of wire half a turn ,and 10 feet,5 or 6 turns. It all depends on the material being used and how "springy" it is. Now wrap the wire into a series of coils and you have a spring. So understanding those parameters I decided the only way to accurately reproduce the spring was to count the coils. As this is a close wound spring the coils all touch the next. After a slow, laborious process, I arrived at the figure of 319. It is agreed the spring wire diameter is .018. So 319 x .018 = 5.742. In comparing this length with the original it appeared way too short.(The old spring was more than 1 inch longer). To verify my math, I measured 1 inch of the new spring which is 55 coils. And doing the math that way I came up with 5.8 inches. So to be reasonable and at least find a starting point, I settled on 5.75 inches of spring.
Before that post was added to the forum thread, I first made a spring using the estimated length as noted above. The original OEM necklace is made out of an extension spring, using 3/32 .018 wire. That specific wire can be hard to find, but a very close approximation is a 1/8 .018 wire that is available from on-line sources such as McMaster-Carr (
www.mcmaster.com, this example was $4.00 plus s/h for a 36" length). The 1/32 difference in outside diameter (OD) should not matter for purposes of this part. Because the old spring was deformed and stretched, the new first piece that was cut for this project was about 1/2" shorter total length (7.5") than the original spring.
After completing the spring (described below) and reassembling the motor, however, the motor was inconsistent on start-up. Sometimes it fired right up, other times it growled, grumbled and just threw sparks. Eventually, it became apparent that perhaps the new 7.5" spring was too long, in large part thanks to the efforts of the person who posted the technical information about how a spring works and how its true length can be determined. So this motor was taken back apart again to make a shorter spring. The number of coils on the damaged OEM coils were counted, and arrived at a similar number of coils per inch and a similar number of 325 total coils. Using that reference for confirmation, I created another, smaller, new spring that was 6" long. Here you can see the two new springs, the original at 7.5" and the smaller one at 6".
Making a SpringOne of biggest challenges in making a new spring is figuring out how to connect the two ends solidly, without distorting the ring or adding significant weight through a blob of solder, etc. The original necklaces were intertwined with one end twisted tightly inside the other end. Try as you might, though, that is a real challenge to do by hand. An alternative is to use a tiny connecting stud that threads inside the two ends of the spring. A 6-32 machine screw happens to fit almost perfectly inside the threads of the 1/8 .018 wire. Take a 6-32 machine screw, count up eight threads from the end, and cut it off, leaving a 1/4" miniature allthread stud.
Replacing the Brushes
New brushes can be found on-line and are not particularly expensive. This new pair was found at Eurton Electric (
www.eurtonelectric.com) for $25 plus s/h. These are called "Brushes with wire and connected in pairs, no terminals." When I did this project in 2012, they were found at this page on the Eurton Electric website:
http://store.eurtonelectric.com/brushesfloorequipment196a-2.aspx. They certainly look better than the old ones.
