Page Revision: 2019/02/25 10:11
1 - Site of manufacture
2 - User’s Manual
3 - Casting Marks & Parts Prefixes
4 - Tops and Extensions
5 - Fence
6 - Fence Locking Lever Knob
7 - Fence Micro-Adjustment Knob
8 - Rear Fence Rail Locking Thumb Nut
9 - Fence Rails
10 - Miter Gage
11 - Blade Guards
12 - Cabinet
19XX the dust door opening changed to have two 6" long tabs on the sides (one each side) and two tabs on the top 2" long. These tabs are for the dust door to rest against. A late 1947 saw exhibits these tabs, so this change must have been made sometime prior to that date.
13 - Cabinet Bottom
14 - Dust Door
15 - Tilt Scale
16 - Switches & Switch Plates
17 - Motor Cover
1939: The cast iron goose egg motor cover (LTA-474) was made available as an accessory (Cat. No. 1454). It weighs 23 pounds and held in place by four #12-24 x 1/2" Indented Hex Head Self-Drilling screws. Photo credit goes to User:Torquester: http://vintagemachinery.org/classifieds/images/14616-3-z.jpg.
UPDATE 2019: The screws were originally documented here as 1/4-20 x 1/2" (in 2008), but User:antioxidant found #12-24 x 3/4" to be a perfect fit on his machine. 1/2" length was simply too short. The #12-24 thread matches the miter gauge's threads as well.
18 - Handwheels
19 - Handwheel Tightening Knobs
20 - Serial Number Plate
21 - Base (Feet or Plinth
22 - Motors
  • No. 8200 – ½ HP 1725 RPM
  • No. 8210 – ½ HP 1425 RPM
  • No. 8250 – ¾ HP 1725 RPM
  • No. 8260 – ¾ HP 1425 RPM
  • No. 8300 – 1 HP 1725 RPM
  • No. 8310 – 1 HP 1425 RPM
Three-Phase Motors:
  • No. 8400 – ¾ HP 1725 RPM
  • No. 8410 – ¾ HP 1425 RPM
  • No. 8450 – 1 HP 1725 RPM
  • No. 8460 – 1 HP 1425 RPM
  • No. 8500 – 1 ½ HP 1725 RPM
  • No. 8510 – 1 ½ HP 1425 RPM
Direct Current Motors:
  • No. 8600 – ½ HP 1725 RPM
  • No. 8610 – ½ HP 1425 RPM
  • No. 8650 – ¾ HP 1725 RPM
  • No. 8651 – ¾ HP 1425 RPM
  • No. 8700 – 1 HP 1725 RPM
  • No. 8701 – 1 HP 1425 RPM
23 - Drive Train
