Page Revision: 2011/04/03 01:41
A difficulty in the design of these drill presses, as well as other manufacturers', is that when the spindle is installed, the spindle pulley is fully captive within the head casting, so a belt cannot simply be slipped over the top of the spindle pulley for installation. Some users get around this difficulty by installing link belts on their drill presses, which can be decoupled at a link, slid around the pulley, and reattached. Others have been able to successfully install a v-belt through the opening on the top of the head casting with the spindle still intact.
The following approach, which shows how to drop the quill and spindle out of the head casting, takes about 15 minutes once you've done it a couple times and is what you would do if you're installing a belt as part of a broader machine restoration anyways.
Start by removing the return spring cover, shown below. Remove the machine screw that bolts the cover to the casting, making sure not to let the cover itself work loose from its stationary position snug against the head.
Unrestored return spring cover
