Page Revision: 2009/01/17 23:57
- 1. The first serial number system began in 1939. These followed no logical pattern and were more akin to a model number than a unit-specific designation. See the machine-specific section below for details.
| C | Sander | | L | Lathes |
| | | S | Spindle Shaper |
- 4. The last serial number system began in October of 1956. The machine type is designated by a two-digit prefix, e.g., No. 11-0001 was the first 20-inch drill press as of October 1956. This system continued until Delta/Rockwell's serial number system replaced it. Walker-Turner machines with a Rockwell serial number badge should be dated according to the Delta Serial Numbers page. Most Rockwell built Walker-Turner machines came from either their Bellefountaine or Tupelo plants.
15-inch Drill Press
Type 1:
| 9D140 | 1-1140 |
| 9D1040 | 1-944 |
| 9D943 | 1-147 |
Type 2:
20-inch Drill Press
Type 1:
| D11241 | 2-1143 |
| D11242 | 2-644 |
| D11542 | 27-1144 (PF) |
| D11642 (PF) | 27-546 (PF) |
| D1143 | 2-546 |
Type 2:
Bandsaws¶
Type 1:
BW740, 1950: 29-449
BN905 14” Wood, 1939 to 1950:
| 9BS6390 | 20-842 |
| MBS6390 | 20-1049 |
| MBS842 |
| 11056390 | 1105842 |
| 11051039 | 21-842 |
| 1105442 | 1105-448 |
| 11351039 | 22-639 |
| 11356390 | 1135-448 |
Type 2:
Tablesaws
Type 1:
| 26-1847 | 26-248 |
| 26-148 | 26-748 |
| 11CS241B | 16-1147 |
| 16-241 | 16-1148 |
| 16-544 | 16-548 |
| 16-546 | 16-749 |
Type 2:
| “D” indicates TA1182 |
Radial Drills
Type 1:
RD1170* Radial Drill Press:
| RD1410 | RD1141B | RD642S | 6-642 |
| RD642 | RD642L | 5-642 | 6-645 |
| 3-642 | 4-642 | 5-645 | RD-242L |
| 3-645 | 4-645 | RD-642LS | RD-2426L |
- RD1170- Radials differ from RD1175J only in manner of mounting motor.
RD1175J* Radial Drill Press:
| RD242B | 7-6248 | RD642JS | 10-642 |
| RD11242B | RD642JL | 9-642 | 10-645 |
| RD642B | 8-642 | 9-645 | 10-6248 |
| 7-642 | 8-645 | 9-6248 |
| 7-645 | 8-6248 | RD-642JLS |
- RD1175J- Radials are the same as present models with the exception of Head Casting and Jackshaft Housing. Other parts are interchangeable.
Type 4:
16-0001 thru 16-0099
17-0001 thru 17-0099
16-0100 and higher
17-0100 and higher
Jig Saws (Scroll Saws)
Type 1:
MJ744, dates unknown: 7JS1239
J782, dates unknown: 7JS240
J915*, 1947 to 1959: 25-1147
- J915 – and model 4510 are identical with the exception of the 45A62 Hold Down and Guide Assy. The new assembly is interchangeable in its entirety.
Type 4:
Lathes
Type 1:
SVL52, 1944: 14-144
L752, 1939: 9L8390
L905, 1939: 7L6390
L1152, dates unknown:
| 1152841 | 14-841 |
| 11L341 | 14-947 |
| 112841 |
Type 2:
Type 4:
Sanders¶
Type 1:
SM700-705, 1939 to 1960:
| 7SN6390 | 13-6390 |
| 7SN1139 | 13-1139 |
Type 4:
Jointers
Type 1:
P908, 1940: 8J240 & 12J240
Type 2:
Type 3:
Type 4:
Shapers
Type 1:
S1140, 1949 to 1953: 14-149
S1141, 1949 to 1953: 14-3249
Type 2:
Type 4:
Radial arm saws
Type 1:
| 27-449 | 28-449 |
| 27-1149 | 28-1149 |
| 27-549 | 33-1149 |
| 34-1149 |
| RA9390 | RA143WR |
| RA510 | RA343HB |
| RA5410 | 23-243 |
| RA540 | RA343 |
| RA640 | RA642 |
| RA642 | 3-1949 |
| 11RA343 |
Type 2:
- Some 4200 series units were produced with an A. O. Smith direct drive motor. These proved highly unsatisfactory and were discontinued immediately. Some difficulties will arise on radial saw parts orders due to our lack of Parts Manuals and a lack of any manufacturing records. All orders for gearhead motor parts MUST include the “GB” number of the motor. This is our only positive identification of the motors since H.P etc....or manufacturer's serial numbers do not mean anything. Any questions on these machines should be referred to Headquarters Office. (Note: The preceding was kept intact purely due to the fascinating insight it provides into the service of these machines).
Cut-off Machines
Type 4:
