Page Revision: 2014/01/10 09:13
Type 1: The first serial number system began in 1939, although not all machines had them that year. These followed no logical pattern and were more akin to a model number than a unit-specific designation. Some of the numbers indicate the year that the model was introduced (not necessarily built) as the last two digits. See the machine-specific section below for details. Note that although the original document lists serial numbers with dashes, the numbers that were stamped onto the badges often used a space instead.
Sam's Vaginal Mesh Lawsuit Blog
Sam's Blog
Early Type 1 tag. 900 series drill press, serial 9DP1040. Contributed by Dan Hoenish.
Typical Type 1 tags. BN905 bandsaw, serial 19-639, contributed by Mike Wiggins. BW740 bandsaw, serial 29-449, contributed by Rich McGowen.In 1948 Walker-Turner was sold to Kearney & Trecker. At some point thereafter the tags were changed to read "Walker-Turner Division of Kearney & Trecker".
Kearney & Trecker era Type 1 tag. TA1180BN tablesaw, serial 161149. Contributed by Mark Ebarc.Type 2: Starting in April of 1950 a new system was introduced. These new serials are formatted YYTSQV where YY is the year of manufacture, T is the type of machine, S is the specific model of machine, Q is the quarter of the year of manufacture, and V notes variation from the standard model. For example, 52DA2A is a standard (52DA2
A) single-spindle (52D
A2A) 15" drill press (52
DA2A) that was built in the 2nd quarter (52DA
2A) of 1952 (
52DA2A). Details about the second letter code ("S" above) is included in the machine type breakdown. Below is a list of the machine type code letters ("T" above) and what they stand for.
| C | Sander | | L | Lathes |
| | | S | Spindle Shaper |
Typical Type 2 tag. 900 series drill press, serial 50DH2E. Contributed by Joe Wells.Type 3: The next serial number system was introduced in April 1953 and used through September 1956. Each machine was numbered 0000001, 0000002, etc. The type and model cannot be identified by the number alone. Machine tags used during this time included fields for both Model No. and Serial No. Almost all of the models sold during this time were introduced in 1953.
Typical Type 3 tag. 1216-41 drill press, serial 0000381. Contributed by Neil Bellenger.In May of 1956 Kearney & Trecker sold its Walker-Turner Division to Rockwell. At some point thereafter the tags were changed to read "Walker-Turner Division of Rockwell". It is currently unknown if this change occurred before the start of Type 4 serial numbers.
Typical Type 4 tag. 1100 series drill press, serial 11-3579. Contributed by Charlie Wells.This system continued until Delta/Rockwell's serial number system replaced it. Walker-Turner machines with a Rockwell serial number badge should be dated according to the
Delta Serial Numbers page. Most Rockwell built Walker-Turner machines came from either their Bellefountaine or Tupelo plants.
Example of a dual Walker-Turner / Rockwell badged machine. Note that the fields on the Walker-Turner tag are blank. 31-600 sander, serial CQ-9464 which dates to 1961 per the Delta Serial Numbers page. Contributed by Rich McGowen.Detailed Information by Machine Type
15-inch Drill Press
Type 1:
900 Series, 1940 through 1947: 9DP140,
9DP1040*, 9DP943,
1-1140,
1-944,
1-147* At the time of writing, the only Type 1 drill presses in the Photo Index have serial number 9DP1040. None have been entered for 9DP140, 9DP943. The original Walker-Turner serial-number document gave the codes as 9D140, 9D1040 and 9D943 but we assume that , in fact, the code
DP and not
D was used to indicate the 15-inch drill press.
Type 2:
50DH2E,
51DM1A,
51DJ3A,
Type 3:
Model 1216-26
0000224
Model 1216-42
0000807,
0001028Type 4:
15" Series15" Series Type 4 examples from the owwm.com Photo Index:
Model 15-146
1352081
20-inch Drill Press
Type 1:
Type 2:
Type 4:
1100 Series: 11-3151Bandsaws¶
Type 1:
19-639, 19-1049
1105842,
21-842, 1105-448
11356390,
22-639, 1135-448
Type 2:
| “B” indicates MBN935 | | “E” indicates MCB1151 |
BW740: 51BA4A
BN905: 51BC3AType 3:
3220: 0000571
3331: 0000820Type 4:
3200 Series: 32-0036
Tablesaws
Type 1:
16-241,
16-544,
Type 2:
| “D” indicates TA1182 |
TC996/2100: 52AB2AType 3:
Type 1:
7-642,
7-645, 7-6248, RD642JL,
Type 3:
1612-2: 0000015Type 4:
- 16-0001 thru 16-0099
- 17-0001 thru 17-0099
- 16-0100 and higher
- 17-0100 and higher
Jig Saws (Scroll Saws)
Type 1:
MJ744, dates unknown: 7JS1239
J782, dates unknown: 7JS240
J915*, 1947 to 1959: 25-1147
Type 2:
51JA4AType 3:
4510: 0001000,
0001817Type 4:
Lathes
Type 1:
SVL52, 1944: 14-144
Type 2:
Type 3:
5110: 0000969,
2000719Type 4:
Sanders¶
Type 1:
Type 3:
5510: 0002914Type 4:
Jointers
Type 1:
P908, 1940: 8J240, 12J240*
Type 2:
Type 3:
6520-1: 0002092,
8000795Type 4:
Shapers
Type 1:
S1140, 1949 to 1953: 14-149
S1141, 1949 to 1953: 14-3249
Type 2:
Type 4:
Radial Arm Saws
Type 1:
23-243, RA343, RA642, 3-1949
Type 2:
Cut-Off Machines
Type 4:
Vertical Blind &
Jasa SEO
