Page Revision: 2009/01/17 21:33
- 1. The first serial number system began in 1939. These followed no logical pattern and were more akin to a model number than a unit-specific designation. See the machine-specific section below for details.
| C | Sander | | L | Lathes |
| | | S | Spindle Shaper |
- 4. The last serial number system began in October of 1956. The machine type is designated by a two-digit prefix, e.g., No. 11-0001 was the first 20-inch drill press as of October 1956.
15-inch Drill Press
Type 1:
| 9D140 | 1-1140 |
| 9D1040 | 1-944 |
| 9D943 | 1-147 |
Type 2:
20-inch Drill Press
Type 1:
| D11241 | 2-1143 |
| D11242 | 2-644 |
| D11542 | 27-1144 (PF) |
| D11642 (PF) | 27-546 (PF) |
| D1143 | 2-546 |
Type 2:
Bandsaws¶
Tablesaws
Radial Drills
Jig Saws (Scroll Saws)
Lathes
Sanders¶
Jointers
Shapers
Radial arm saws
Cut-off Machines
