Page History: Yager/K2000 parts list and dismantling
Page Revision: 2009/12/09 14:55
Yager Thickness Planer - serial number 1779
1 Guide Pin (Table) 2
2 Outfeed Roll (Rubber Covered)
3 Dowel Pin 4
4 Pinion Shaft Pin
5 Table Adjusting Screw
6 Pinion Shaft for FP-25 Gear
7 Brass Table Washer (Thrust) 2
8 Cutterhead Bearing 2
9 Infeed and Outfeed Roll Bushing (Short) 2
10 Base Casting (Grey Iron)
11 Right Side Casting (Gear Side)
12 Left Side Casting
13 Gear Cover Casting
14 (Optional) Feed Roll Handcrank
52 (Optional) Feed Roll Driver Pulley (8A x 1/2” Bore)
15 Table Casting
16 In and Outfeed Roll Bushing (Long) 2
20 Compression Spring (Feed Roll) 4
22 Cutterhead (Cylindrical)
23 Cutterhead Screw (5/16-24 x 1.2 Spline) 15 .23
24 Cutterhead Backup Plate (Plain) 3
26 Infeed and Outfeed Roll Gear 2
29 Handwheel (Aluminum for Table Raising)
30 Indicator Scale
31 Infeed Roll (Steel-Serrated)
32 Planer Knives (Plain) 3
33 Nameplate
34 Cutterhead Pulley (2-1/2A x 5/8” Bore)
36 Chipguard
61 Handwheel Cross Shaft 1 1.20
62 Mitre Gears (for Table Raising-Steel) 2
64 Indicator Scale Pointer
65 Gear Cover Casting 10-24 x 1 1/4” Round Head Screws 4
66 Side Casting 5/16-18 x 1-1/2” Hex Head Cap Screws 8
67 Cutterhead Bearing Retaining Screw
