Delta 14" Bandsaw Type Study
Modified on 2009/04/01 23:02 by joewells — Categorized as: Uncategorized
1934 - 1936 14" Bandsaw
Models:
890- Bare Bandsaw, 892- Woodcutting Unit, 896- Metalcutting Unit
Wheel Cover Decal:
Delta Specialty decal
Wheel Cover Knobs:
LBS 177 Knurled steel
Wheel Cover Type:
Stamped steel with rounded edges on the face, three raised rays, and raised center hub.
Serial Number Badge:
None
Patent Decal:
1934 saws lack the patent decal.
Color:
Wheel Type:
Solid steel dish-type
Table:
?x?, no miter slot
Stand Types:
891- Steel Stand
Switch Plate:
None
Switch:
Switch installed in motor, 851- Switch Rod available.
Motor Options:
800- 1/3 hp split-phase, 900- 1/3 hp R-I, 820- 1/2 hp R-I
Belt:
Belt Guard:
None available.
Blade:
93" standard, 105" with riser block
Accessories:
882- lamp, 894- 6" riser block, 893- fence w/ 18" rails, 895- fence w/ 32" rails
Lower guide separate from lower trunnion assembly.
1937 Improved 14" Bandsaw
Models:
890- Woodcutting, 880- Metalcutting
Wheel Cover Badge:
Red circle, three vertical stripes, DELTA angled up from left to right.
None
Patent Decal:
Yes
Knobs:
Knurled steel
Wheel Cover Type:
Stamped steel with rounded edges on the face. Lacks the raised rays and hub from the previous version.
Color:
Wheel Type:
Stand Types:
Switch Plate:
Switch:
Motor Options:
Belt:
Belt Guard:
Cast iron belt guard available
Blade:
Accessories:
