Delta 6x48 Sander Miscellaneous
Modified on 2019/08/06 14:05 by bullmastiff — Categorized as: Restoration Topics, Sanders
Alright
Ok
Getting Better
Pretty Good
Awesome
Additional Detail Pictures
These details show various problems one can encounter when buying a used sander
belt sander body details
Table and inside groove:
Lower sanding cut:
Tension Screw Repair
By
bullmastiff
It was my wife's fault: 1952 Delta 6x48 Belt Sander, mostly
This is an alternative to the solution presented below to the problem of the tension screw wearing against the inside of the casting, allowing the end of the tension screw to protrude past the plane of the platen and get in the way of sanding. The
idea
came from scw1991 from the thread
By
Bob Vaughan
The bad shoulder
All Better
Fabricating Tensioner Parts
By
Jeff Miller
My $200.00 Delta sander pictuers
I brought home a sander with the spring and sleeve missing from the belt tensioning mechanism.
I studied the parts breakdown pic., bought some springs (TSC) used some 1" square tubing welded some small ears on the end that pulls on the dog to push up on the idler, welded a piece on the other end and drilled a 1\2" hole in it found a square 7\16" nut. I gussed on the length of tubing and length of springs. I have a new 7\16" rod I am going to thread yet but wanted to make sure it would work first. And it works really well. Total cost $11.00
Luke Hargenrader's sander with attractive shop made base
