Delta 6x48 Sander Shafts
Modified on 2018/04/21 16:40 by bullmastiff — Categorized as: Bearings, Restoration Topics, Sanders
Removing Upper Shaft
Removing spindle from Delta 6x48 sander.. continued
Rockwell 6x48 Belt Sander Bearings
Delta sander 31-710 bearing removal
Rockwell 6x48 sander
Starting rebuild of 31-710 belt/disk, any hints?
Belt sander upper shaft details
Comparisons to Powermatic 30
By Bob Vaughan
6x48 sander drum shaft sizes
Shaft Fabrication
By Bob Vaughan
Shaft fabrication is easy with a metal lathe. Take 15mm ground rod (see links below for source) and thread the ends to fit the fine nuts you have. Newer shafts have different threads to older ones (see pictures above).
Delta 6x48 upper (idler) shaft question?
Bearing Information
When fitting extended race bearings to this sander, the extended portion of the race should be exposed to the elements, that is the races of the two bearings should extend away from each other.
Opps, 31-710 sander, ext. races, in or out? Dr. Vaughan?
