Page Revision: 2008/07/26 22:51
Back to main Babbitt Page
History
Types of Babbitt
Selecting a Type of Babbitt
Babbitt Classification LIMITS
Surface Speeds
(# of Ft/min)
LOAD
(Lbs/sq.in.)
MIN. MAX. MIN. MAX.
Calculate Surface Speed
Where:
Pi = 3.1416
RPM = Revolutions Per Minute
Calculate Bearing Load
Bearing Load = W / ID x L
Where:
100 / 2 x 4 = 12.5 lbs/sq in
Lead Based Babbitt
Tin Based Babbitt
Recycling Babbitt
ASTM Babbitt Analysis Chart
ASTM B-23
  Chemical
Composition, %
Tin Base Babbitt Grades
ALLOY NUMBER (GRADE)
  1 2 3 11
Lead 0.35 0.35 0.35 0.50
Iron 0.08 0.08 0.08 0.08
Arsenic 0.10 0.10 0.10 0.10
Bismuth 0.08 0.08 0.08 0.08
Zinc 0.005 0.005 0.005 0.005
Cadmium 0.05 0.05 0.05 0.05
Total named
elements, min
99.80 99.80 99.80 99.80
  Chemical
Composition, %
Lead Base Babbitt
  7 8 13 15
Copper 0.50 0.50 0.50 0.6
Iron 0.10 0.10 0.10 0.10
Bismuth 0.10 0.10 0.10 0.10
Total named
elements, min
