Page Revision: 2008/07/27 08:47
Back to main Babbitt Page
History
While Babbitt metal is soft and can be easily damaged when treated improperly, and seems at first sight an unlikely candidate for a bearing surface, its appearance is deceptive. The structure of the alloy is made up of small hard crystals dispersed in a matrix of softer alloy. As the bearing wears the harder crystal is exposed, with the matrix eroding somewhat to provide a path for the lubricant between the high spots that provide the actual bearing surface.{Reference:http://www.frymetals.com/products/babbitt.html?product=babbitt|Fry Metals Babbitt Reference Guide}
Types of Babbitt
The term "Babbitt" is commonly used to describe any kind of "white metal" bearing material no matter the actual composition. Babbitt metals can generally be broken into two major families: tin based or lead based. Tin based Babbitt is the best choice for high speed or hard to lubricate bearings whiel lead based works best with low speed or heavy load bearings.{Reference:http://www.alchemycastings.com/lead-products/babbitt.htm|Alchemy Castings, Inc., Babbitt Metal}
Selecting a Type of Babbitt
To determine which bearing material would be best for your application, use the following are suggested guidelines: {Reference:http://www.alchemycastings.com/lead-products/babbitt.htm|Alchemy Castings, Inc., Babbitt Metal}
Babbitt Classification LIMITS
Surface Speeds
(# of Ft/min)
LOAD
(Lbs/sq.in.)
MIN. MAX. MIN. MAX.
Calculate Surface Speed
Where:
Pi = 3.1416
RPM = Revolutions Per Minute
Calculate Bearing Load
The Load the bearing is required to carry is the weight which is being exerted through the combined weights of the shaft and any other direct weights on the shaft and measured in pounds per square inch.{Reference:http://www.alchemycastings.com/lead-products/babbitt.htm|Alchemy Castings, Inc., Babbitt Metal} For most old wood working machines, the load on the bearings is not a major concern as the weight to surface area ratio is usually great enough to not be an issue. Load come more into play when you are using extremely heavy shafting over long stretches, such as in line-shaft applications where there is a lot of weight hanging on a couple of small bearings. Even though load will probably not bear into the decision making on the type of babbitt on most woodworking machines, it is still a good idea to calculate this value to be sure.
Bearing Load = W / ID x L
Where:
100 / 2 x 4 = 12.5 lbs/sq in
Lead Based Babbitt
Tin Based Babbitt
Recycling Babbitt
  Chemical
Composition, %
Tin Base Babbitt Grades
ALLOY NUMBER (GRADE)
  1 2 3 11
Lead 0.35 0.35 0.35 0.50
Iron 0.08 0.08 0.08 0.08
Arsenic 0.10 0.10 0.10 0.10
Bismuth 0.08 0.08 0.08 0.08
Zinc 0.005 0.005 0.005 0.005
Cadmium 0.05 0.05 0.05 0.05
Total named
elements, min
99.80 99.80 99.80 99.80
  Chemical
Composition, %
Lead Base Babbitt
  7 8 13 15
Copper 0.50 0.50 0.50 0.6
Iron 0.10 0.10 0.10 0.10
Bismuth 0.10 0.10 0.10 0.10
Total named
elements, min
