Page Revision: 2008/07/26 13:46
Back to main Babbitt Page
History
Types of Babbitt
The term "Babbitt" is commonly used to describe any kind of "white metal" bearing material no matter the actual composition. Babbitt metals can generally be broken into two major families: tin based or lead based. Tin based Babbitt is the best choice for high speed or hard to lubricate bearings whiel lead based works best with low speed or heavy load bearings. Here is a breakdown of several common types of Babbitt that are still commercially available and commonly used when restoring old machinery:
Lead Based Babbitt
Within the category of the lead based babbitts, there are several types - such as a lead based coppered babbitt. While still classified as a lead based babbitt, this mid-grade Babbitt product, it is generally considered a better material than plain lead based babbitt because of the alloy mix. An example composition of this type would be approximately 74.5 lead, 14.75 percent antimony, 10 percent tin, 0.25 percent copper and 0.5 percent arsenic. With twice as much tin as plain lead based Babbitt, as well as some copper and arsenic, this Babbitt is stronger and more suited for heavy loads. Still only recommended for low speed applications - not what you would want to use on a jointer or planer head but probably plenty adequate for a band saw with wheels only turning in the 400-500 RPM range. Prices vary but expect to pay around $6.00 per pound. For no more than it cost, this Babbitt would nearly always be preferred over plain lead based. Pouring Temperature is 700 degrees F.
Tin Based Babbitt
ASTM B-23-83 Babbitt Specifications
  Chemical
Composition, %
Tin Base
  1 2 3 11
Lead 0.35 0.35 0.35 0.50
Iron 0.08 0.08 0.08 0.08
Arsenic 0.10 0.10 0.10 0.10
Bismuth 0.08 0.08 0.08 0.08
Zinc 0.005 0.005 0.005 0.005
Cadmium 0.05 0.05 0.05 0.05
Total named
elements,
min
99.80 99.80 99.80 99.80
Recycling Babbitt
