Page Revision: 2008/07/26 22:28
Back to main Babbitt Page
History
Types of Babbitt
The term "Babbitt" is commonly used to describe any kind of "white metal" bearing material no matter the actual composition. Babbitt metals can generally be broken into two major families: tin based or lead based. Tin based Babbitt is the best choice for high speed or hard to lubricate bearings whiel lead based works best with low speed or heavy load bearings. To determine which bearing material would be best for your application, use the following guidelines:
Babbitt Classification LIMITS
Surface Speeds
(# of Ft/min)
LOAD
(Lbs/sq.in.)
MIN. MAX. MIN. MAX.
Calculate Surface Speed
Where:
Pi = 3.1416
RPM = Revolutions Per Minute
Calculate Bearing Load
Bearing Load = W / ID x L
Where:
100 / 2 x 4 = 12.5 lbs/sq in
Lead Based Babbitt
Lead Based Babbitt is the least expensive babbitt that you can buy. It is also the softest type of Babbitt. While this material would work fine for light duty and low speed applications such as a band saw arbor, for just a little more money, you can get a much better quality tin based material.
Within the category of the lead based babbitts, there are several types - such as a lead based coppered babbitt. While still classified as a lead based babbitt, this mid-grade Babbitt product, it is generally considered a better material than plain lead based babbitt because of the alloy mix.
Tin Based Babbitt
Among the many standards ASTM has, different grades of Babbitt are included. As such, many manufacturers of Babbitt will often provide a ASTM Grade for different brands of Babbitt, allows consumers to compare one product to another knowing that its composition is similar.
ASTM Babbitt Analysis Chart
ASTM B-23
  Chemical
Composition, %
Tin Base Babbitt Grades
ALLOY NUMBER (GRADE)
  1 2 3 11
Lead 0.35 0.35 0.35 0.50
Iron 0.08 0.08 0.08 0.08
Arsenic 0.10 0.10 0.10 0.10
Bismuth 0.08 0.08 0.08 0.08
Zinc 0.005 0.005 0.005 0.005
Cadmium 0.05 0.05 0.05 0.05
Total named
elements, min
99.80 99.80 99.80 99.80
  Chemical
Composition, %
Lead Base Babbitt
  7 8 13 15
Copper 0.50 0.50 0.50 0.6
Iron 0.10 0.10 0.10 0.10
Bismuth 0.10 0.10 0.10 0.10
Total named
elements, min
Recycling Babbitt
