Page Revision: 2008/04/04 12:37
Here's some pics of digging into a Baldor motor to repair a bad centrifugal switch posted by Bob Vaughn here http://owwm.org/viewtopic.php?t=31506.
Remove the fan cover
Remove the motor bolts
Here's the end bell
Here's the end bell
