Page Revision: 2008/04/10 03:33
Here's some pics of digging into a Baldor motor to repair a bad centrifugal switch posted by Bob Vaughan here. in this example, the contacts were damaged and needed repair.
Remove the fan cover
Remove the motor bolts
Here's the end bell
Here's the end bell
