Page Revision: 2008/04/10 15:26
Here's some pics of digging into a Baldor motor to repair a bad centrifugal switch posted by Bob Vaughan {Rating:http://owwm.org/viewtopic.php?t=31506|http://owwm.org/viewtopic.php?t=31506}. In this example, the contacts were damaged and needed repair.
Remove the fan cover
Remove the motor bolts
Here's the end bell
Here's the end bell
