Page Revision: 2008/04/12 12:53
Many thanks to all who have shared their bearing knowledge in the forums. In particular, Frans Grove and Bob Vaughan for their insightful posts which provided much of the material in this wiki.
Ball Bearing Primer
High Speed Bearings
Bearing Lifespan
  • bearing type
  • bearing size
  • operating speed
  • operating temperature
  • vibration levels
  • level of contamination
Grease Life
Felt Bearing Seals
Bearing Quality
ABEC 1NormalP0
ABEC 3Class 6P6
ABEC 5Class 5P5
ABEC 7Class 4P4
ABEC 9Class 2P2
ABEC 10.015|| 0.00059
ABEC 30.0100.00039
ABEC 50.0080.00031
ABEC 70.0040.00016
Bearing Clearance Classes
http://www.ntnamerica.com/pdf/2400/brgclear.pdf http://www.ntnamerica.com/pdf/2200/tolrance.pdf
Bearing Shelf Life
Bearing Fit on A Shaft
Heat Mounting
Purchasing Bearings
Bearing Nomenclature
This will help decipher what all the letters and number in a bearing code mean.
http://www.ahrinternational.com/HYATT-BALL-BEARINGS_nomenclature.shtml
http://www.gizmology.net/bearings.htm
http://www.ahrinternational.com/ahr_bearing_part_number_systems.shtml
Bearing Manual
http://www.owwm.com/files/PDF/FAQ/BearingID.pdf
