Page Revision: 2017/12/10 21:45
Here is an interesting video showing how bearings are made. It appears to be an NTN factory in Canada.
High Speed Bearings
Bearing Lifespan
  • bearing type
  • bearing size
  • operating speed
  • operating temperature
  • vibration levels
  • level of contamination
Grease Life
Cleaning Old Bearings for Regreasing
Drain the solvent and wash the bearing(s) in a second or third container of clean solvent until the bearings are completely clean. When the bearings are clean, they should immediately be protected against corrosion, and the solvent should be removed as it will break down any new grease packed in the bearing.
The clean bearings can be dried by using compressed air, but be *very* careful to hold both rings tight. Blow air into the bearing while holding both rings static. If the bearing is allowed to spin during drying, then the bearing can easily reach extreme speeds and with no oil in the bearing, the races will be damaged very quickly. Also make sure clean, dry air is used.
Another method is to shake most of the solvent from the bearings and then spin it by hand in light oil. The oil will remove the solvent. Wipe off the excess oil from the bearing surfaces, but make sure a thin coat stays for corrosion protection.
Do not give in to the temptation to use way oil or motor oil in bearings. Way oil is intended for for lathe ways and other sliding machine parts especially on metal working machines. As such it has different properties that make it unsuitable for use in bearings sticky, evaporates slowly, not easily washed away by cutting oil, resists drying, low resistance to heat. etc. Motor oil contains detergents to clear and engine of the products of combustion. Not necessary or desirable in an OWWM.
Felt Bearing Seals
Bearing Quality
ABEC 1NormalP0
ABEC 3Class 6P6
ABEC 5Class 5P5
ABEC 7Class 4P4
ABEC 9Class 2P2
ABEC 10.0150.00059
ABEC 30.0100.00039
ABEC 50.0080.00031
ABEC 70.0040.00016
Bearing Clearance Classes
Bearing Shelf Life
Bearing Fit on A Shaft
Heat Mounting
Nilos Ring
Nilos Ring
Purchasing Bearings
Where is it Made??
Where is it Made??
Bearing Nomenclature
Accurate Bearing's interchange guide, courtesy owwm.com (PDF)
SKF Specific Suffix Information
The designation suffixes used to identity certain features of SKF deep groove ball bearings are explained in the following.
CN Normal radial clearance; normally only used together with an additional letter that identifies a reduced or displaced clearance range
H Reduced clearance range corresponding to the upper half of the actual clearance range
L Reduced clearance range corresponding to the lower half of the actual clearance range
P Displaced clearing range comprising to the upper half the actual clearance range plus the lower half of the next lager clearance range
* The above letters are also used together with the clearance classes C2, C3, C4 and C5, e.g. C2H
C2 Radial internal clearance smaller than Normal
C3 Radial internal clearance greater than Normal
C4 Radial internal clearance greater than C3
C5 Radial internal clearance greater than C4
DB Two single row deep groove ball bearings matched for paired mounting in a back-to-back arrangement
DF Two single row deep groove ball bearings matched for paired mounting in a face-to-face arrangement
DT Two single row deep groove ball bearings matched for paired mounting in a tandem arrangement
E Reinforced ball set
GJN Grease with polyurea thickener of consistency 2 to the NLGI Scale for temperature range –30 to +150 °C (normal filling grade)
HT Grease with polyurea thickener of consistency 2 to the NLGI Scale for temperature range –40 to +150 °C (normal fill grade)
J Pressed steel cage
LHT23 Grease with lithium thickener of consistency 2 to the NLGI Scale for temperature range –50 to +140 °C (normal filling grade)
LT Grease with lithium thickener of consistency 2 to the NLGI Scale for temperature range –55 to +110 °C (normal filling grade)
LT10 Grease with lithium thickener of consistency 2 to the NLGI Scale for temperature range –50 to +90 °C (normal filling grade)
M Machined brass cage, ball centred; different designs and material grades are identified by a figure following the M, e.g. M2
MA Machined brass cage, outer ring centred
MAS As MA but with lubrication grooves in the guiding surfaces
MB Machined brass cage, inner ring centred
MBS As MB but with lubrication grooves in the guiding surfaces
MT33 Grease with lithium thickener of consistency 3 to the NLGI Scale for temperature range –30 to +120 °C (normal filling grade)
MT47 Grease with lithium thickener of consistency 2 to the NLGI Scale for temperature range –30 to +110 °C (normal filling grade)
N Snap ring groove in outer ring
NR Snap ring groove in the outer ring, with appropriate snap ring
N1 One locating slot (notch) in one outer ring sideface
P5 Dimensional and running accuracy to ISO tolerance class 5
P6 Dimensional and running accuracy to ISO tolerance class 6
P52 P5 + C2
P62 P6 + C2
P63 P6 + C3
RS1 Sheet steel reinforced contact seal of acrylonitrile-butadiene rubber (NBR) on one side of the bearing
2RS1 RS1 contact seal on both sides of the bearing
RSH Sheet steel reinforced contact seal of acrylonitrile-butadiene rubber (NBR) on one side of the bearing
2RSH RSH contact seal on both sides of the bearing
RSL Sheet steel reinforced low friction contact seal of acrylonitrile-butadiene rubber (NBR) on one side of the bearing
2RSL RSL low friction contact seal on both sides of the bearing
RZ Sheet steel reinforced low friction seal of acrylonitrile-butadiene rubber (NBR) on one side of the bearing
2RZ RZ low friction seal on both sides of the bearing
TH Snap-type cage of fabric reinforced phenolic resin, ball centred
TN Injection moulded snap-type cage of polyamide, ball centred
TNH Injection moulded snap-type cage of glass fibre reinforced polyetheretherketone (PEEK), ball centred
TN9 Injection moulded snap-type cage of glass fibre reinforced polyamide 66, ball centred
VL0241 Aluminium oxide coated outside surface of the outer ring for electrical resistance up to 1 000 V DC
VL2071 Aluminium oxide coated outside surface of the inner ring for electrical resistance up to 1 000 V DC
WT Grease with polyurea thickener of consistency 2-3 to the NLGI Scale for temperature range –40 to +160 °C (normal filling grade)
Y Pressed brass cage, ball centred
Z Shield of pressed sheet steel on one side of the bearing
2Z Z shield on both sides of the bearing
ZNR Shield of pressed sheet steel on one side of the bearing and snap ring groove in the outer ring with snap ring on the opposite side of the shield
2ZNR Z shield on both sides of the bearing and snap ring groove in the outer ring with snap ring
1939 New Departure Bearing Handbook Volume 1
1939 New Departure Bearing Handbook (Dimensions, load ratings, bearing fits)
New Departure Bearing Cross-Reference c.1961
http://wiki.vintagemachinery.org/GetFile.aspx?File=Ball_Brg_Cross_Ref\ND Brg Guide.pdf
Electric Motor Bearing Reference c.1963
http://wiki.vintagemachinery.org/GetFile.aspx?File=Ball_Brg_Cross_Ref\Motor Ball Brg 1963.pdf
