Page Revision: 2008/04/04 17:57
by Keith S. Rucker
Part 3 - Finishing up
  • Part 1
  • Part 2
1 - Sunday, December 5, 2004
1.1 - Mount Bearings
1.2 - Installing New Tires
I ordered my tires from Carter Products Company, Inc. I decided to go with the black Stretch On Rubber Tires rather than the "Ultra Blue" Urethane Tires simply because the blue tires would not look original on my restored saw. I also ordered two part epoxy to cement the tires to the rims of the saw. The tires came complete with instructions, written by none other than OWWM's own Bob Vaughn! Figuring that Bob knows well what to do, I followed the instructions to the tee.
 Notice slight crown in center of wheel. You can see light under both sides of the straight edge. The crown is actually greater than what this picture looks like.
2 - Tuesday, December 7, 2004
Saturday, December 11, 2004
Monday, December 13, 2004
Saturday, December 18, 2004
