Page Revision: 2008/09/25 16:33
  • Crescent 12” Jointer (1903, 1904, 1910, 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945, 1946)
  • Crescent 16” Jointer (Introduced in 1912,1916,1918,1921,1923,1925,1928,1930,1939, 1945, 1946)
  • Crescent 18” Jointer (1903, 1904, 1910, 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945)
  • Crescent 20” Jointer (Introduced in 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945)
  • Crescent 24” Jointer (1903, 1904, 1910, 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945)
1903 Crescent Catalog
The Front Table is 42 -inches long; the rear table is 36 inches long, and is arranged for rabbeting. The Fence can be set to any angle from 90° to 45° and can be moved to any position across the table. It is furnished with one pressure spring to hold the work to the table.
12-Inch.18-Inch.24-Inch.
Floor space required, aver all31x8037x8043x80
Cubic Measure, boxed for export  40ft.48ft.56ft.
Gross Weight, boxed for export1,5001,7752,000
Net Weight1,2501,4501,650
List Price for Machine$150$170$190
Telegraph Code WordEnnovelar.  Ennoyage.  Ennuvear.
