Page Revision: 2008/10/03 10:12
  • Crescent 12” Jointer (1903, 1904, 1910, 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945, 1946)
  • Crescent 16” Jointer (Introduced in 1912,1916,1918,1921,1923,1925,1928,1930,1939, 1945, 1946)
  • Crescent 18” Jointer (1903, 1904, 1910, 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945)
  • Crescent 20” Jointer (Introduced in 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945)
  • Crescent 24” Jointer (1903, 1904, 1910, 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945)
1903 Crescent Catalog
The Front Table is 42 -inches long; the rear table is 36 inches long, and is arranged for rabbeting. The Fence can be set to any angle from 90° to 45° and can be moved to any position across the table. It is furnished with one pressure spring to hold the work to the table.
12-Inch.18-Inch.24-Inch.
Floor space required, aver all31x8037x8043x80
Cubic Measure, boxed for export  40ft.48ft.56ft.
Gross Weight, boxed for export1,5001,7752,000
Net Weight1,2501,4501,650
List Price for Machine$150$170$190
Telegraph Code WordEnnovelar.  Ennoyage.  Ennuvear.
1910 Catalog
The Crescent Jointers 8, 12, 18 and 24-Inch
A JOINTER is sometimes also called a hand-planer, or a buzz-planer. The machine is used for straightening lumber. It will plane one surface straight and out-of-wind; by use of the fence it will also bring one surface, on dimension stock, square with another, or on accurate bevel with another. It is not intended for surfacing boards to uniform thickness. For such use a regular planer or surfacer must be used. By use of special cutters a jointer is often used for beading, grooving, making light molding and other similar work.
Length of Knives  12 in.18 in.24 in.
Length of front table  42 in.42 in.42 in.
Length of rear table  36 in.36 in.36 in.
Width of tables  17 in.23 in.29 in.
Height of table from floor  33 ½ in.33 ½ in.33 ½ in.
Size of flanged pulley on head  4 x 4 ½ in.  4 x 4 ½ in.  4 x 4 ½ in.
Widest belt that should be used  4 in.4 in.4 in.
Size of bearing on pulley end  1 ½ x 7 in.1 ½ x 7 in.1 ½ x 7 in.
Size of bearing on operator end  1 ½ x 5 in.1 ½ x 5 in.1 ½ x 5 in.
Size of tight and loose pulleys  10 x 5 in.10 x 5 in.10 x 5 in.
Speed of countershaft per minute  800 rev.800 rev.800 rev.
Giving head a speed of  4,000 rev.4,000 rev.4,000 rev.
Floor space, exclusive of countershaft  31 x 80 in.37 x 80 in.43 x 80 in.
Cubic measure, boxed for export  33 ft.49 ft58 ft.
Gross weight, boxed for export  1,400 lbs.1,650 lbs.1,900 lbs.
Domestic shipping weight  1,275 lbs.1,500 lbs.1,700 lbs.
Square Head, regular solid lips  No. 121No. 181No. 241
Telegraphic code word  EldenEnlinEnome
Square Head, steel 1ips  No. 122No. 182No. 242
Telegraphic code word  EratoGandeGamon
Safety Head, regular solid lips  No. 123No. 183No. 243
Telegraphic code word  GowanHectiHenco
Safety Head, steel lips  No. 125No. 185No. 245
Telegraphic code word  HeranHamarHymen
