Page Revision: 2009/07/17 19:02
by Keith S. Rucker
An ongoing project of the Old Woodworking Machines web site is to document as many examples of machines and their serial numbers made by the Crescent Machine Company, OH as possible. The reason we want to document these machines it in order to create a rough timeline as to when a machine was made by Crescent. Our theory is that if we can create a database of Crescent machines and their serial numbers, we can begin to look for the subtle changes made by Crescent over the years as they improved their machinery which can be determined by old Crescent catalogs, ads and similar documentation.
View the current Crescent Machine Company Serial Number Registry
1 - Notes about Crescent serial numbers
2 - Serial Number Series
  • 12345 - A four or five digit number This style of serial number is the most common of all serial numbers and was used by Crescent from their earliest days up until around 1947 or 1948. It is possible that less than four digits may have been used on the very earliest of machines but no examples of a serial number with less than four digits have been seen. The lowest number serial numbers seen to date have at least four digits.
  • CA-1234 - The serial number prefixed by the letters "CA" began around 1947 or 1948. These serial numbers have all been found a small red tag with both the Crescent and Rockwell names. This style of serial number was used until at least 1949.
  • 1234-A - This serial number group is somewhat confusing. Around 1947 or so, the Crescent factory began making several machines that were designed by Delta. These machines included the Delta 20" Band Saw, the Delta 12-14" Table Saw and the Delta 8" jointer (the 8" jointer was really more of a hybrid of Delta and Crescent designs). When these machines left the factory, they were badged as being both Delta and Crescent machines. The current theory is that when Crescent began doing this, they put a different serial number tag on these machines that said "Delta Power Tool Division, Rockwell Manufacturing Company, Milwaukee 1, Wisconsin." This is when we believe that the serial numbers suffixed with the letter "A" began.
  • 1234-B - Our current theory is that when Crescent used serial number 9999-A that they went to 0001-B. Dates of when this conversion took place are currently unknown.
  • C-1234 - The serial numbers prefixed by the letters "C" are machines made after Rockwell sold the Crescent line to Enterprise and were used up until at least the early 1970's.
  • E-12345 - One Crescent machine has been found with a serial number prefixed by the letter "E". It is currently unknown how this machine fits into the whole serial number scheme. The one machine with an "E" series was badged as being made by Enterprise - perhaps hence the "E"?
3.1 - Serial Number Tags
This style tag is found on early Crescent machines. Exact dates are not known at this time but appears to have been used from around 1906 through around 1912. When this tag was not used, serial numbers were simply stamped on the machine.
Sometime around 1940 or so (an exact time is not currently known), Crescent once again began to use a serial number tag on their machines rather than just stamping the number directly on the machine. These tags were used between when they started using tags again and when Crescent was bought out by Rockwell in 1945. During this period of time, Crescent used several style badges with known examples show below:
Another example of the early 1940's tag.
Also during this period (probably during WWII), Crescent used a tag made out of thick paste board - probably due to the shortage and rationing of metals during the war. Exact range of dates this tag was used is unknown but probably between 1942 and 1944. Below is a rare example of this tag as many have not survived due to them being made out of paper:
This style tag was used for a short period of time after Rockwell took over Crescent in 1945 until they began using the serial numbers prefixed with the letters
This style tag was used for a short period of time after Rockwell took over Crescent in 1945 until they began using the serial numbers prefixed with the letters "CA-" around 1948.
This style of tag began showing up on Crescent machines after serial numbers began using the
This style of tag began showing up on Crescent machines after serial numbers began using the "CA-" prefix. Use began around 1948 and continued until at least 1949.
This serial number tag with the name
This serial number tag with the name "Delta Mfg Division" has been found on machines that were of both Delta and Crescent designs but made at the Crescent factory. The serial numbers on this tag are all suffixed with the letter "A". These machines were badged with both Delta and Crescent logos. Used approximately between 1949 and 1951,
These serial numbers were all suffixed with the letters
These serial numbers were all suffixed with the letters "A". Use began around 1951 to sometime in 1952.
This serial number tag with the name "Delta Power Tool Division" started to be used around 1952 and was used until Crescent was sold to Enterprise in 1953. The serial numbers on this tag are suffixed with either the letter "A" or "B" depending on when they were made. These machines were badged with both Delta and Crescent logos.
Serial number tag used on Crescent machines built by The Enterprise Company - these machine were made from about 1953's on.
3.2 - Stamped Serial Numbers
3.2.1 - Jointers
On jointers, the serial number is typically stamped onto the end of either the in-feed or out-feed table.
3.2.2 - Band Saws
Some serial numbers on Crescent band saws have been found stamped under the main table.
Serial numbers are often found on the front side of the upper arm of the saw stamped onto upper wheel adjustment device.
Serial numbers have also been found stamped onto the wheel and shaft of the upper band saw wheel as above.
On a very early four digit serial number 20
On a very early four digit serial number 20" band saw, the serial number was found stamped on the front arm.
Serial number stamped on the back side of the upper front arm on a 20
Serial number stamped on the back side of the upper front arm on a 20" Crescent Band Saw
3.2.1 - Planers
At least one serial number has been found on the base of the machine on the out feed side.
If you are able to find a serial number on your Crescent machine, please Submit your Serial Number Information
We also would strongly encourage you to Submit Photos to the OWWM Photo Index.
  1. Use the Crescent Machine Registry to determine where your machine falls into the current list of machines. Where we can provide dating information about a particular machine, we try to include it in the registry.
  2. Look at the collection of Publication Reprints listed in the Manufacturers Index entry for Crescent Machine Company. Often, you can use old catalogs to help determine a time frame your machine might have been made.
  3. Call Alloy Machining to see if your machine is in their records. Alloy Machining is the current owner of the old line of Crescent machines. They have some records of when machines were made - mostly from the early 1940's onward. They may not have your machine in their records but if they do, they can provide you with the date that it was made and very often other information on your machine. Alloy Machining can be reached at (330) 482-5543. Here is a collection of Crescent Machine Records that we have scans of right now. If you have or get a Machine Record for a Crescent machine, please share an image of it with us.
